Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-08-2010, 08:05 AM
Psi For Fun is on a distinguished road
nexus 200 crashed now off center
Nexus 200 MY: Barfeeder fed out double the material and tool tried to face off in the middle of the part which doesn't work all that well. After getting things cleaned up, new inserts and such I made another part only the find the drilled and tapped hole in the center was in fact not in the center. The hole was drilled and tapped using live tools if that makes a difference. Any help here would be appreciated. Thank You
Old 11-08-2010, 09:45 AM
tompartridge is on a distinguished road
Sounds like the same as happened to our a couple of months back sorry to say it was a job for the mazak engineers to come out and realign your turret.
They took just about a day to do ours last time but make sure you have them check the allignment with all the tool holders!!
Old 11-08-2010, 10:01 AM
Thank You for the info! I believe Mazak will be on the call list today. I know our last machinist had done the alignment on his own once. We had a similar problem before and had Mazak here to align it and ever since he had done this on his own. Thank You again
Old 11-27-2010, 09:24 PM
dvolgstadt is on a distinguished road
Should try doing tram and sindle taper on it. Bot are easy procedures which someone in your shop could do within a few hours.
Old 11-29-2010, 10:18 PM
cnc doc is on a distinguished road
would your application allow to push to a stop on the turret? if so this is always safer as any load is excerted to the bar feeder. and the machine is not in rapid traverse or something. also these turrets are very simple to align and also simple to rest the x axis 0. pay attention to the mazak guy so not to have to pay again. also for 500 dollars you could send an employee to mazak for training on the machine this is much cheaper than even one visit from mazak.
EC2.3.5 Crashed erlyrisa LinuxCNC (formerly EMC2) 0 07-29-2010 12:50 AM
Need Help!- Crashed Our VF-2 Need help DaOne Haas Mills 8 04-20-2009 02:24 PM
center drill diameter developpement on mazak nexus 640m mill Denis13 Mazak, Mitsubishi, Mazatrol 0 01-30-2008 08:56 PM
Crashed my lathe, now tool is above center protrxrptr17 General Metal Working Machines 8 04-23-2007 09:22 PM
SMTC crashed JPMach Haas Mills 5 03-16-2006 07:16 PM
