Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-04-2010, 09:15 PM
kendo is on a distinguished road
finish tool in slot unit
the endmill cant be smaller than half the slot width or the control alarms out.
Is there any way to change this?
Old 11-04-2010, 11:23 PM
MrMazak is on a distinguished road
Use Line-In
Old 11-06-2010, 07:58 PM
so, is there any way to change this?
Old 11-08-2010, 10:30 PM
epmtool is on a distinguished road
There is nothing I know that you can do. It's just one of the many frustrating things about mazatrol.
Old 11-08-2010, 11:13 PM
What's frustrating is people that can't use a different unit to accomplish this cut and continue to whine about it. Use line-in and it's done.
Old 11-09-2010, 05:04 AM
sorry, but since I've been working around mazaks, theres been probably 10 little issues like this that cause the programmer/operator undue frustration in the process of developing part programs.
Most of the time I encounter this "dont whine about it" attitude from the other programmers who have gotten used to mazak.
But about half the time I find some parameter buried in mazaks arcane manuals that alleviate the problem
SO they just didn't have the brains to dig deep enough and figure it out, they'd rather just call someone a whiner and keep doing it the way they're used to
Old 11-10-2010, 12:43 AM
christinandavid's Avatar
christinandavid is on a distinguished road
Yo kendo, how did the arc probing go? Was the built-in 3-point cycle suitable or did you write your own cycle?
DP
Old 11-10-2010, 11:28 AM
Wheelz is on a distinguished road
DP
I gather you're not talking about a Mazatrol MMS unit for 3 pt probe?
www.tsw.net.nz
Old 11-10-2010, 02:45 PM
heres the thread: http://www.cnczone.com/forums/mazak_...obing_arc.html
I didn't do much more with that arc probing, The owners were asking be about a part we might end up doing, and I was just looking into it.
I have thought about it quite a bit though. I plan on writing a macro that uses the target radius to compute the expected error and compensate, maybe even probe the two outside points using a perpendicular approach vector to get even closer. Also, the tiniest probe stylus I can find will help out too.
I've spent the meantime writing a few simpler macros and learning the tricks to get them to execute correctly when called from within a mazatrol main program. My last macro was for slotting with a trochoidal motion, it works good, but obviously I'm still learning. (or trying)
Need Help!- M32 Positioning for automatic tool measuring unit Bullet605 Mazak, Mitsubishi, Mazatrol 9 12-21-2010 06:28 AM
X3 finish surface tool paths billholeman Mastercam 6 12-29-2008 08:31 AM
T slot tool post with drill bit tool holder brucesu1 CNC Tooling 0 06-09-2008 05:04 AM
"tool slot number too large" code dave6 Mach Mill 1 10-10-2006 05:57 PM
powermill and slot cutting with woodruff tool krustykrab General CAM Discussion 2 02-23-2006 04:25 AM
