Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-01-2010, 11:45 PM
schmitty9 is on a distinguished road
Heavy Tool No Decel
Im working on a Nexus 510C and I am typing in Heavy on the ID code and it will not decelarate the rapid movement of the Tool changer? Any suggestions?
Old 11-04-2010, 11:32 AM
jimiscnc is on a distinguished road
I know the perfect thing to accompany this man's trumpet. None other than the mighty and majestic Albert Hall Pipe Organ.
Sorry. Wrong subject.
I experimented with this capability at length while I was at Mazak and it's an interesting legacy issue. From my highly scientific lab type of study, I found there is no discernable difference WHAT SO EVER in tool change time between a "normal" tool and a "heavy" tool, so I think this DOES NOT WORK on a 510C.
I climbed up and messed with a hyd circuit that drives the TC and found that if you mess with it, it heats up and e-stops the machine.
For the 510C, anyway, I suspect the heavy tool capability is there only because it's a legacy kind of thing, and it probably only works on certain specific machines, that would probably use 30 to 50 pound CAT-50 type tools.
You can slow down the whole TC event globally with the hyd circuit I messed with, but not much, and I think the two speed tool change capability (heavy=slow, normal=fast)does not even exist on this particular machine model.
-90% Jimmy,
embittered ex-mazak sour grapes ex-employee,
But I'm doing MUCH BETTER now
Old 11-05-2010, 11:22 PM
Thanks I kind of figured it was something machine specific considering we have some newer model horizontal mills that the heavy id code works with slowing the atc down and im doing the same thing.
Sent from my DROID2 using Tapatalk
Heavy 2X4 Router gd.marsh DIY-CNC Router Table Machines 80 11-17-2010 06:35 PM
Heavy is good??? zaebis Syil Products 4 05-28-2009 07:17 AM
heavy gantry drafterman JGRO Router Table Design 6 11-07-2007 10:59 AM
Spindle accel/decel load fpworks Fadal 2 10-30-2006 09:09 AM
Decel/Accel jdnoe CamSoft Products 11 08-31-2006 11:23 AM
