Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-28-2010, 07:46 AM
Sirwhinesalot is on a distinguished road
Mazak 640 t fusion Parameters
We replaced our hard drive, old one currupted. Had to manually put parameters back in ( user and machine) Need access to spindle parameters but cant find its location.
Old 10-28-2010, 07:20 PM
Rokkin is on a distinguished road
If you replaced only the hard drive, you should not have to reload any parameters because they are held on the control. The hard drive is merely a backup location for parameters. If anything you should be backing up data to the hard drive, not reloading data from it in this case.
Why do you need the spindle parameters?? Do you have any alarms that you did not mention?
Need Help!- Mazak Fusion 640 T Keyboard fbergski Mazak, Mitsubishi, Mazatrol 5 02-25-2010 11:26 AM
Problem- backlash parameters Fusion 64 control birchie Mazak, Mitsubishi, Mazatrol 1 09-15-2008 10:03 PM
Mazak Fusion Memory Mark18969 Mazak, Mitsubishi, Mazatrol 1 01-07-2008 01:52 PM
Mazak 640 m fusion question nightshift Mazak, Mitsubishi, Mazatrol 1 08-13-2007 12:50 PM
fusion mazak mill wireguy Mazak, Mitsubishi, Mazatrol 8 06-17-2005 09:20 AM
