Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-14-2010, 06:24 AM
Carnedude is on a distinguished road
Mazak QT-20 HP Spindle Error
We have a lathe listed in the subject and one morning I came, fired it up, homed it out, and chucked on a part I was working on the day before and the spindle ran for a few seconds then stopped. It gave me a spindle start error. I hit reset looked at the control and the chuck clamp light was lit. I hit start again and the spindle ran again for a second or 2 then it stopped and alarmed again. Since that morning it has done this for the first 30 minutes or so after the machine is turned on and then the problem stops for the rest of the day. The time the spindle runs before alarming out is not consistent, sometimes a second or two sometimes it will run for several minutes. Once it has ran a bit though it never does it again throughout the day. Any ideas?
Old 10-15-2010, 10:29 AM
erdinct's Avatar
erdinct is on a distinguished road
have spindle driver an error on it's numerik display any. can you see. if it has not any error maybe can wait something. speed, pressure vs vs
Need Help!- Mazak CAM T4 parameters error winds1sj Mazak, Mitsubishi, Mazatrol 0 06-09-2010 02:59 PM
Need Help!- Mazak Vqc 20/40B error massage evrgrecnc Mazak, Mitsubishi, Mazatrol 5 05-07-2010 03:57 AM
Mazak QT-6T Program Error flomatic Mazak, Mitsubishi, Mazatrol 4 04-07-2010 11:10 AM
Mazak M32-Parity H Error compuslave Mazak, Mitsubishi, Mazatrol 4 02-04-2009 03:25 PM
Mazak VTC20 error ZipSnipe Mazak, Mitsubishi, Mazatrol 1 09-22-2006 11:46 AM
