Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 09-07-2010, 04:57 PM
kendo is on a distinguished road
probing an arc
I've got a part about 3 inches wide and 25 inches long with a big 19" radius arc segment cut into it and so Im wondering how to probe 3 points and find the actual radius.
If I manually do a circle measure and hit three points will that be correct?
Is there a way to do it automatically in an MMS unit?
Thanks,
Kenny
Old 09-07-2010, 05:57 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Seem to recall that even dedicated CMMs have trouble with small section/large radius measurements, accuracy improving with each point probed...would be surprised if you could get consistent results using only 3 points.
DP
ps Ignore that post as I may have got the wrong end of the stick and thought you were probing a radius over the 3" width
Old 09-08-2010, 06:27 AM
thanks for the reply,
you're right, the radius is cut into the long side so I've got a section about 20" long, but the three points will be probed in the same +Y direction and I'm sure it'll be a little off.
The first pic shows what Im doing, the second shows the error I'm expecting.
Old 09-08-2010, 08:56 AM
A quick calculation (roughly scaling your drawing and using the error as a guide) I reckon the machine will think the radius is .1" smaller than it actually is if you probe those points in one direction.
Unless of course it can compensate for the probe knowing the angle it is at, in relation to the origin of the radius.
DP
Old 11-10-2010, 06:39 PM
Wheelz is on a distinguished road
Don't know if this will be of any help or not, but assuming you're still not at the automated stage, we use this 3 point macro on our Kitamura 2Xi with very good accuracy results.
Our machines are all metric so the variables will likely differ but the math and layout should be the same.
Be sure to move on both axes on all 3 points. (Else divide by zero error)
Had to zip the file as file with no extension is considered invalid.
Pete
File Type: zip o9006.zip‎ (600 Bytes, 10 views)
www.tsw.net.nz
probing Freddy Bastard Tormach PCNC 6 08-21-2009 10:02 PM
Probing? anyone? Freddy Bastard Tormach PCNC 2 07-04-2009 09:07 PM
Probing? chunkymonkey General Metal Working Machines 2 04-01-2008 11:39 PM
Probing with Turbo CNC btalon TurboCNC 1 02-23-2008 07:19 PM
Probing geverhart WoodWorking 1 09-03-2004 02:41 PM
