Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-09-2005, 05:32 PM
imwllc is on a distinguished road
g-code on my mazatrol machine
i have a 98 mazak quick turn 20 with the t+ control, a service man who was working on a machine said that control came loaded and that the g-code programming just needs to be turned on, but he didnt know the process to do so, he seemed kind of full of b.s. when he talked so i wasnt sure if he knew or not. does anyone know if this is possible?
Old 06-09-2005, 07:09 PM
psychomill is on a distinguished road
Check your "Option" page to see if you have "EIA/ISO" highlighted. If so, then yes, you can program/run in G code. ( To check your options, push ' Diagnostic > Version > Option ' ). To program, just push " Program > Work number > " , then the soft keys should prompt you for Mazatrol or EIA/ISO. Push "EIA/ISO" then you can program G code.
You can program g code inside of Mazatrol also. Just use the "Manual Entry" button when programming.
The option is software related ( I believe ) so I'm not sure what he meant by turning it on,.... unless he saw something in the ladder to make him believe it was loaded.
Old 06-12-2005, 09:42 AM
dmealer's Avatar
dmealer is on a distinguished road
Hello
We have a old Mazak VQC VMC. We want to do G-code on it also, but it will have to have a EIA translator card installed. The cost of this from Mazak will make you faint.
About $5000.00 for the card.
Dalen
Old 06-12-2005, 12:22 PM
what was explained to me is that mazak machines are all loaded with all the software, and the options are turned on somewhere, he says that is why it understands g code in the manual program and in mdi. I somewhat beleive him, at a shop i used to work at there was a ajv and a vqc mill, and a service man "turned on" the graphics and these machines never had them before
Old 07-02-2005, 02:24 PM
WayneHill's Avatar
WayneHill is on a distinguished road
Start a new program and see if it asks for a Mazatrol or EIA/ISO format.
Wayne Hill
www.codemangler.com
Old 02-04-2011, 09:46 AM
brenato is on a distinguished road
Question
Hi there!
Is there any way to the eia/iso program communnicating with user?
Mazak FJV-20 / Mazatrol M-PLUS with eia/iso.
I would like to send text messages to display while the eia/iso program running.
I found NC alarm command:
#3000=21(HELLO-WORLD).
Its working, but it is break the operation
#3006=1(HELLO-WORLD).
ITs an optional stop, but in this case user need to press the start button again.
Generate NC warning? (Blue text)
Change the program name between two G codes?
Is there any other ways to send something to display?
Thank you!!!
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 04:08 PM
Confused about CNC software samualt General CAM Discussion 22 06-30-2005 09:18 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 03:58 PM
Using Boss4 code in Boss9 machine pcsimp Bridgeport and Hardinge Mills 2 03-21-2005 08:56 AM
FeatureCAM Expands Product Offering with Machine Simulation CNCadmin Product Announcements & Manufacturer News 0 01-21-2005 07:58 PM
