Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-27-2010, 02:15 AM
Namnp2007 is on a distinguished road
Change units on Meldas 500 series
Hi all.
Now I can't change the default units on my Meldas 500 controller, it's allways fix in inch. Pls. guide me how to change it to mm units. I mean the system unit, not the input value( I used g21 to change to mm input, but all value still inch units).
Help me, pls.
Thanks.
Old 08-29-2010, 06:53 PM
Rokkin is on a distinguished road
Originally Posted by Namnp2007 View Post
Hi all.
Help me, pls.
Thanks.
Check your CONTROL PARAMETERS for "Initial Inch". Turn it off (unhighlight it) and then power off/on.
Old 08-29-2010, 08:49 PM
Thanks Rokkin so much, I solved the problem.
Mitsubishi Meldas M65 tool change problem tbilecen Mazak, Mitsubishi, Mazatrol 1 08-19-2010 06:23 PM
Need Help!- How do you change language to English on a Meldas 310L CNC. emudziviri UG NX 0 03-26-2010 10:47 AM
language change on meldas 310 zvizdic Mazak, Mitsubishi, Mazatrol 4 03-30-2009 08:28 AM
How to change to Baudrate on Meldas 300 Series Controller? Josh Lehman Mazak, Mitsubishi, Mazatrol 1 01-16-2009 04:20 PM
language change on meldas 65-M scale Mazak, Mitsubishi, Mazatrol 0 12-23-2008 03:22 AM
