Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-20-2010, 12:44 PM
Batfood is on a distinguished road
Mazatrol 640m EIA/ISO Sub Program, Incremental repeat
I need an EIA/ISO Sub Program to efficiently cut a big-ish 45 degree chamfer using a ball nose cutter.
I want to position the cutter at a point in X,Y and Z, then call up the Sub Program to incrementaly move the cutter down in Z and along in Y or X at a given depth and distance. I want to repeat this process in even values until the material is removed.
I've been using a 45 degree cutter in Mazatrol until now, but tool life is useless when cutting armour plate at 55 rockwell C.
Basically i need a fanuc type canned cycle.
Any help would be appreciated or i'm working Sunday.
Bat.
Old 08-20-2010, 03:37 PM
CNCRim's Avatar
Cycle time will increase dramatic if you do that, good news is it's can be done. Create zigzag pattern as subprog and repeat many times you like(one program for X and one for Y.
Mazatrol 640M/ Matrix Post BryCAM Mazak, Mitsubishi, Mazatrol 1 04-27-2012 01:30 PM
Need Help!- Sm1 well versed with mazatrol 640m or atleast ne mazatrol naren1608 Mazak, Mitsubishi, Mazatrol 0 03-22-2010 05:29 AM
Mazatrol 640M/ EIA program inkydo69 Mazak, Mitsubishi, Mazatrol 5 07-02-2009 05:00 PM
incremental repeat function? Joe Miranda Milltronics 13 05-20-2008 10:10 PM
Need Help!- Mazatrol 640M hense Mazak, Mitsubishi, Mazatrol 2 02-11-2008 11:56 PM
