Results 1 to 2 of 2
Thread: Mitsubishi Meldas M65 tool change problem
    Feb 2010
    turkey
    Hi
    i have HARTFORD OMNIS 1020 with Mitsubishi M65.
    My problem is about tool change.
    i have tried
    M6 T**
    T** M6
    both combinations directly act like i use only M6
    to get the right tool, i have to write T** (tool number) and M6 at seperate lines.
    when i do this, machine stands still until next tool gets prepared.
    is there any parameter setting or G-Code system to get ready my next tool while machining continue?
    Apr 2009
    We have Mits horizontals with 520 control. We have to run our code like this
    T1 (WORKING TOOL)
    T2 M6 (T2 PRECALL NEXT TOOL)
    It was pretty annoying it will alarm out if you call the tool already in the spindle.
    OU812
  1. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 05-04-2010, 01:40 PM
  2. how to change tool offset memory type on meldas 500?
    By Francois_DCM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2010, 09:12 AM
  3. Need Help!- Problem in mitsubishi meldas
    By mazman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-30-2009, 07:36 AM
  4. Mitsubishi Meldas - Switching Tool Offset Page Type
    By avongil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2008, 03:20 PM
  5. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-19-2007, 12:48 AM
