| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
I am using a quick-turn 28n with a mazatrol t-23-2 control. I need to produce a taper with the smallest end towards the chuck and the bigger end towards the tailstock. I only need about .005 of taper. If i try to do this in a normal turning cycle i get the alarm Reverse contour. I know that i could manually program this but i would rather not because this taper is just a small part of a fairly complex part. Is there another way? Thanks Brad |
| Brad, Are you using the taper option in the program? If you are then your problem possibly lies with the way your tool is described in the tool page. If you are decribing say a CNMG 432 insert it will give you trouble due to the geometry. Try decribing a 35 or 55 deg turning tool. John |
| "reverse contour" is due to violate program parameter. Change the parameter it will go away. I believe the default is .002, to test this try program it with taper .0018 smaller and if it is work then ...... change parameter.
__________________ The best way to learn is trial error. |
| I don't think so, "reverse contour" alarm only programming side. Unless someone can prove me wrong.
#11
| Unfortunately i can't attach a photo of the program because it has already been deleted. I ended up making a small "manual programming" to finish turn the trouble spot. It worked out for me. I would like to have played with this problem more but i just didn't have the time. Next time i have some free time i will try to figure it out. It could very well be something small that i have overlooked Thanks for the tips. |
| Quick Change 40 Taper Tooling | ktmrider | CNC Tooling | 1 | 12-28-2009 10:03 PM |
| Turning off the door sensor on a mazak quick turn 6t lathe | redfishoil | Mazak, Mitsubishi, Mazatrol | 2 | 05-01-2009 09:48 AM |
| Problem- reverse on lathe (turn M3 to M4) | Igor_UA | LinuxCNC (formerly EMC2) | 6 | 11-02-2008 01:57 AM |
| Need Help!- Mazak Quick Turn 350 | T.J | General Metalwork Discussion | 0 | 05-14-2008 06:19 AM |
| HF 8x12 quick reverse | Ed Boysun | Mini Lathe | 0 | 12-19-2006 09:58 PM |
