Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-23-2010, 06:40 AM
flomatic is on a distinguished road
Red face Not able to Key In System Parameters
Hi All. My Battery in the NC System of my QT-6T cnc lathe has died off.
I have replaced the battery and have since re-initialise the system. I have keyed in the machine and user parameter, but i am not able to key in the system parameter (option, servo, spindle parameter).
Attached is the picture showing the problem. Can anyone expert help me on it?
Thanks again.
Old 07-24-2010, 06:56 AM
jimiscnc is on a distinguished road
Perhaps you need to get into "Privilege mode"?
I got this instruction from a google search that is from another cnc oriented website.
"From the Position Screen, press the Display Select key (Left most arrow key)
Press Diagnos, Version, Menu Select (Right most arrow key) then type in 1131 then press input. You are now in Privilege Mode"
from memory - press the new version softkey on the right and that gets you to other parameters normally closed.
you should do this again to get out of privilege mode, but it is automatically turned off when you power off the machine.
-jim
Need Help!- Fanuc System 6M - parameters/alarms quasarix Fanuc 0 03-18-2010 12:47 PM
Need Help!- Restoring System parameters with A.top mfugs Okuma 4 10-24-2009 01:53 PM
Need Help!- Converting DSP controller system to Mach based system. Marwell Machines running Mach Software 0 12-19-2008 05:00 PM
system variables vs parameters sinha_nsit Fanuc 3 01-17-2008 01:51 AM
parameters mikeh78 Haas Mills 7 05-02-2006 09:20 PM
