Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-22-2010, 05:53 PM
makbari is on a distinguished road
Tap Keep breaking on Aluminium
Does anybody knows how can I fix my tapping problem?!
I work with Mazak 640M and use G84 for tapping after couple holes keep breaking,
I use deffernt kind of tap like Spril point, Sprilt flute even form tap,
I used form tap and used S800 F40. for 1/4-20 and cheaps stick to tap after doing some holes and will break,
I used Spril point, Sprilt flute too with different speed and feed but still keep breaking after some holes, what is wrong?
I am using Coolant for lubrican,
Thnaks Guys
Old 07-22-2010, 06:10 PM
CNCRim's Avatar
Have you try to slow down to S300?
Old 07-22-2010, 07:45 PM
Answer
I have try slow speed with Spril-point and Spril flute one but Form tap supose to do faster, I am not sure if there is any parameter on Mazak that I have to set or not?!
Old 07-22-2010, 08:12 PM
CNCRim's Avatar
Well, whatever you did not work, so it is not right. If you program with Mazatrol then yes there is parameter.... but G-code no.
Old 07-22-2010, 08:32 PM
metalworkz's Avatar
metalworkz is on a distinguished road
Hello,
It sounds like the tap is getting too hot and the chips are bonding to the tap. Perhaps the coolant is not a good cutting fluid for tapping aluminum, so why not try a regular tapping fluid and possibly a fluid made specifically for aluminum? Are the holes the correct size for the taps being used(ie 1/4-20 cut usually .201" dia and for the roll tap the hole needs to be bigger....228" dia. if I remember correctly) Also are the chips being cleared from the hole and how deep are the threads you are cutting, or are the holes blind holes? It all has a bearing on how the tapping will work.
Regards,
Wes
Old 07-22-2010, 09:17 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
you don't say what depth or what type of aluminum your cutting so it's impossible for you to get the right answer to your question , if your tapping very deep then you may need to peck tap it , also if your dealing with soft gummy aluminum then once again you may need to peck ,
you could check the drawing to see what class of thread you need to cut then drill at the top of the tolerance ,
what brand of taps are you using
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 07-22-2010, 10:09 PM
Answer
I am using Nachi Tap HSSE, it is AL 6061, 1/4-20 2B, hole size drill#7,
with Coolant, I am not using Mazatrol code, I am using G-code, and Mastercam to make program, I know there is some parameter for Mazak but not sure if has to be set, and do not know about them what supose to be?!
Old 07-22-2010, 10:59 PM
dertsap's Avatar
Gold Member
you didn't mention the depth but if your depth is above 2/3 to 1 1/2 times dia then min and max hole size is .202-.207 ,
if your above 1 1/2 to 3 times dia then the hole size can be .204-.210
min/max tolerance for a 2b thread
Old 07-23-2010, 07:35 AM
Superman's Avatar
Superman is on a distinguished road
G84, is that a "Rigid Tap Cycle" for the mazak
When, in the cycle are the taps breaking ?
If not a rigid tap cycle
How are your tap being held ?
Are you using a floating holder to allow for the stopping and reversing of the spindle ?
If a thru hole, gun taps may last longer and be a bit stronger
Old 07-23-2010, 10:44 AM
psychomill is on a distinguished road
Depending on your parameter setting (Yes, there is a parameter for G code).... G84 is rigid tapping but NOT synchronoized. You need a floater.
You can try one of 2 things here......
add code if you want to keep using G84
G84 Z-.5 F.05 H1
or change to synchronized tapping code...
G84.2 Z-.5 F.05
In either case, you'll need to use the tap pitch as the feed and not the calculated feed like you have it.... unless you want to use a floater...
I normally do not change the parameter for G84. I generally use G84.2 and that way, I maintain the option of using either tap cycle types if I want (to float or not to float)....
It's just a part..... cutter still goes round and round....
  #11   Ban this user!
Old 07-24-2010, 09:41 AM
steveo is on a distinguished road
coolant
I use G84 all the time in aluminium. higher end sfm the better. thicken your coolant aluminium does not like water. follow your tap manufacturer correct sfm
  #12   Ban this user!
Old 07-24-2010, 10:59 AM
hnevans's Avatar
hnevans is on a distinguished road
Depending on how many parts that you have to run, I recommend just drilling to desired depth and just tapping maybe .500" deep. Afterwards, hand tap to finish depth. This allows the tap be on location and square to surface with minimal hand tapping. Also, there aren't any broken taps to remove. I would run tap at 10 times what ever tpi is and use F10. for feed. For example 1/4-20 run at 200rpms and F10., 1/2-13 run at 130rpms and F10. I am certain this is correct, but I'm at home and unable to ensure that I am right. Therefore, I also advise to try this in a test piece first. It also wouldn't hurt to put an optional stop M01 in program before the tap runs and just add some Rapid Tap or other cutting oil in the holes. I have done this before and it helps as well. I would use a siral flute CNC tap if available. Formula for Feed = pitch X RPM. Therefore, when running other taps use the Feed formula given with 10. as feed and solve for RPM. For example a 1/4-20 would be 10=.05(x) solve for x. With "x" being the RPMs.
Need Help!- breaking taps!!!!! dieman1968 Mazak, Mitsubishi, Mazatrol 8 04-01-2009 04:06 PM
Need Help!- TAPS BREAKING !! weaston General Metalwork Discussion 15 07-07-2008 02:08 PM
Keep Breaking Taps Crashmaster General Metalwork Discussion 7 10-30-2007 02:16 PM
Breaking chips yoopertool CNC Swiss Screw Machines 15 10-18-2007 04:47 AM
Breaking Bits Help ninewgt Composites, Exotic Metals etc 5 03-31-2005 07:23 PM
