If you have a face or shoulder you can take a tool that is set correctly up to, you can write down the machine position. Then move the set tool away and bring out the new drill after you have loaded it. Move it up to the same face and check the machine position. What ever the difference, this is the amount you need to add or subtract from the drill tool data z length to get the position displaying the same value as the set tool gave you.
Jake
LinkBack URL
About LinkBacks
