Look up your model number and maybe you can find a operating manual at Diakin. Yellow-(original is white)= Power On; Green= Cooling: Red= Alarm. The green means the cooling compressor is running. Red can be the high pressure switch has tripped, or a thermal relay for the condenser fan motor or the themal relay for the compressor motor has tripped. HTH.
LinkBack URL
About LinkBacks
