Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-29-2010, 10:56 AM
newbi100 is on a distinguished road
Mazak QT10 T2 Code 22
The machine ran perfect until yesterday afternoon when I received the alsom code 22 NMI Memory Parity. I pressed R and it will not go away. Now I am stuck. Any ideas ? I am not a machine shop just a guy who has a toy that he loves. Please help
Old 06-30-2010, 08:28 AM
onthebumper is on a distinguished road
Check the control unit in the electrical cabinet. Do you see any parity light's on?
If you do then pull out the FX01 or FX701 and flip dip switch 2. Reinstall the board. Make sure it is tight, you need a little bit of force to get it seated in the back connectors. Turn the control on and check the parity lights now. If they are still on then power off and on a few times until they stay off. Give about 5 seconds between powering off and back on the control.
Once the parity lights have turned off flip the switch back without removing the board.
You may have to reload parameters after this is done so make sure you have a back up copy or hard copy.
Need Help!- Mazak QT10 T1 Andycnc Mazak, Mitsubishi, Mazatrol 8 02-09-2010 01:58 PM
MAZAK QT10 & BAR PULLER paul wilcox Mazak, Mitsubishi, Mazatrol 5 05-08-2009 12:39 PM
Need Help!- MAZAK QT10 T-2 STEVEN911 Mazak, Mitsubishi, Mazatrol 3 10-05-2008 08:21 AM
problem with mazak qt10 t1 diz Mazak, Mitsubishi, Mazatrol 16 11-12-2007 10:24 AM
Help with mazak g-code dgchumley Mazak, Mitsubishi, Mazatrol 3 05-02-2007 03:32 PM
