| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hi all I have a VTC200/50 and a relay on a board has gone bad on the tool unclamp solenoid valve, there are spare relays on the board but I can't figure out how to edit the ladder logic. I can only get to the ladder monitor. Thanks Chris |
| On the controller itself, if it is Mazak, I can't help. Al.
| What make is the machine? Is it a Mazak? I see now its a Mits 640M. I am not sure if I have the info for this one and MEAU do not have it on line. If you get stuck, phone mits support in IL and get them to fax the instructions over. Al.
#10
| Thanks I have called and they want you to buy the whole board They will tell you how to edit any ladder logic. I think its crazy to go through all that trouble to resolder a relay when you could just change the address.. Thanks Everyone Chris |
#11
| Can you identify the relay? Some used a printed circuit DIP relay other method was an output driver IC with outboard relay, previously I have located parts and replaced them for small cost. Al.
#12
| Thanks for all the help I have I did find the relay. I ended up unsoldering an unused on and soldering it back in place. I did find a person to give me the code and keystrokes to get into the control but still could not figure out how to edit the ladder. Many Thanks Chris |
| Matsuura MC500 VS Ladder Logic | nnpepe | General Metal Working Machines | 1 | 02-28-2012 09:48 PM |
| Need Help!- CTR counters in Ladder Logic | Adam Rehorn | Fanuc | 0 | 08-07-2009 02:20 PM |
| How to decifer Ladder Logic??? | theemudracer | Fanuc | 6 | 06-01-2008 08:28 AM |
| FANUC Ladder Logic Backwards? | obieron | Fanuc | 4 | 12-18-2007 02:17 PM |
| Ladder logic | Chris Roth | Deckel, Maho, Aciera, Abene Mills | 4 | 12-26-2005 10:29 AM |
