Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-18-2010, 08:58 AM
FanucIssues is on a distinguished road
MR-J2 Controller...Teaching Home directions
Does anyone have directions to teach the MR-J2 controller home position? We are playing with Mazak 280 C Lathe, with 640 Fusion controller. We have replaced the HR-113 Mother board, and the hard drive, Mazak/Mitsubishi had gotten all of the info to load the operating systems...but we have gotten the machine/user parameters loaded, but...well that is another topic...We cant get the programs loaded into the NC either.
The instructions we have for the MR-J2 seem to not be entirely correct, I was wondering if there is a "simple" step by step. The mouse does work...So that is a plus.
Any help would be great.
It's not what you cut...It's what you don't cut.
Old 06-21-2010, 08:14 AM
onthebumper is on a distinguished road
If the data from your old hard drive was saved then you should be able to to an Absolute Position Repair. Go to the start menu and open the MR-J2 software. Under parametrs there is a button labeled ABS Position Repair. If it is grayed out then you will have to manually set home position. If it is in black then you should be able to click on it and restore the home position.
Need Help!- mach 3/controller directions reversed cncbcncb Machine Problems, Solutions , Wireless DNC, serial port 3 03-03-2009 12:14 PM
Controller issues, in the home stretch bp092 Gecko Drives 4 03-18-2008 04:41 PM
My first home built Taig controller nosplinters Taig Mills & Lathes 12 03-11-2008 11:52 AM
Setting up Home & Limit directions widgitmaster Mach Mill 17 02-04-2007 01:02 AM
Home built controller Stephen General Electronics Discussion 1 09-22-2004 11:02 PM
