Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-15-2010, 08:17 AM
FN Smith is on a distinguished road
63 parameter error
Hello all,
I have a Mazak AJV-25/404 with a Mqazatrol M-32.
We recently replaced the 121 card, because of another problem. Would not power up. After replacing the 121 card we cant communicate with computer, CIS 515 Mis connected error. I checked the cables internal and external, both check good. Was waiting for approval to purchase new license..... Now I have a new error 63 parameter error????? All these problems happened within 7-10 days. Any help greatly appreciated. Thanks
Old 06-15-2010, 01:16 PM
I ended up calling Mitsubishi and Mike over there sent me a fax that explained how to diagnose a faulty spindle(which evidently didn't have any LED's lit).
In the diagnostics it explained to remove SF-CA card and large connectors on back, reseat card with out connectors. Power on and check LED's, if LED's on check Base capacitors and resistors, if not replace SF-PS. Well since I had to put everything back together I just tried to power it up...... I'll be damned it worked....... Just reseating the card worked. No need to go further with this problem. We are evidently getting a cascade of problems with this machine and my expertise is with computers and networks, not CNC machine's.
Hope this helps someone else.
Need Help!- How to initial parameter error meldas 300 series gunawan_tehnik Mazak, Mitsubishi, Mazatrol 5 03-24-2012 05:07 AM
Need Help!- Error 414 Z axis error detect- servo alarm andywids Fanuc 0 07-09-2009 10:33 AM
Need Help!- Error 414 Z-axis error detect servo alarm andywids General Metal Working Machines 1 07-09-2009 09:56 AM
machine parameter error Runner4404spd Fadal 3 03-05-2009 09:33 PM
Memory Parameter Error? John3 Fanuc 6 09-07-2007 09:17 AM
