Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-03-2010, 06:06 AM
mt92 is on a distinguished road
Question Matrix tool too long alarm 1109?????
This is on a Mazak SQT250MY
When touching off a tool in the vertical live milling station the machine is giving me a 1109 alarm. The machine will touch it off shorter be that will not work. When the tool is where it needs to be I still have plenty of clearance when homed out in x and rotating the turret.
Does anyone know the setting to change to fix this?
Old 06-03-2010, 07:51 AM
jimiscnc is on a distinguished road
SU154.1
Tool length setting range check function
SU110 to SU113 define a maximum tool size.
SU154.1 = 1 means your tool set values have to fit inside the "box" as defined by SU110-113.
SU154.1 = 0 turns off this check.
So, if you change SU154.1 to 0 this checking function is turned off and you should be able to set tools freely.
Hopefully you can check this in your parameter book, but this s/w enhancement may still be too new to put in the books that come with the machine.
-jim
PS - this is only on MATRIX controls. Matrix is the most profound OVERHAUL of mazatrol controls in the history of MAZAK. M/T 32, M/T + and M/T Fusion have a lot of commonality between them. MATRIX merged the 3 or 4 divergent mazatrol platforms, M, T, MT, and MT-e type, into one platform. Matrix corrected the divergent evolutionary paths of the four basic machine types MAZAK developed over the years and made the programming and parameters more common, regardless of which type of machine the control is attached to.
Old 06-03-2010, 08:32 AM
Wink
Thanks for the help.
Mazak Matrix Tool Path Check McGuiver Mazak, Mitsubishi, Mazatrol 4 07-30-2010 12:36 AM
Need Help!- Tool magazine stuck (AL 212), integrex 400IV Matrix -PC- Mazak, Mitsubishi, Mazatrol 9 02-01-2010 09:43 AM
Matrix Lathe Tool Def Questions microdot Mazak, Mitsubishi, Mazatrol 1 05-01-2009 08:20 PM
tool length to long laamar Mazak, Mitsubishi, Mazatrol 3 02-13-2009 02:50 PM
How long does 'D' last and tool offset for G3? Witsenburg G-Code Programing 1 06-03-2007 03:47 PM
