Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-01-2010, 05:46 PM
rusty1979 is on a distinguished road
mazatrol
help please !
hi all this is my first post !
right i have been pulling my hair out over this i have recently started using mazatrol on a nexus 410a VMC i was wondering if there is at all a mirror function on mazatrol i am fluent to the haas control and used that feature many a time to mirror part on the opposite sides ! i would be gratefull for any help !
Old 06-01-2010, 11:35 PM
CNCRim's Avatar
Go to intergrexmachinist.com, you will get a better help there. I support you can ...... check under user parameter for more info.
Old 06-02-2010, 08:04 AM
jimiscnc is on a distinguished road
mazatrol mirror image
M90 - cancel mazatrol mirror image
M91 mirror WPC-X
M92 Y
M93 4th
I think this should be in an M code unit AFTER the wpc, but I'm not sure. You can have as many WPC units as you like in a mazatrol program. The WPC is modal, the last one read in your program remains active until another one later in the program supersedes it.
write a simple dummy program and see if it works as you like. one thing is that sometimes certain situations do not simulate correctly on the tool path check. might want to cut air in trace mode and run in real time to really see what the machine will do.
note also that the WPC unit has a theta value - you can rotate your shape freely about the WPC part program zero.
got this from a fusion M book, but I suspect it's possible on earlier Mazatrol too?
-jim
Old 06-02-2010, 05:22 PM
thanks for the help guys i found out how to do it you use g51.1 only in iso programming to mirror the desired axis i have succesfully done it now !
also if anyone know how to or if there is a parameter to unlock so u can adjust tool lenghts diameters when running a program on mazaks its a pain having to stop it and start again if u need to adjust it !
MAZATROL T-PLUS CHANDRU Mazak, Mitsubishi, Mazatrol 1 02-22-2012 11:12 AM
Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english tuanpq Mazak, Mitsubishi, Mazatrol 21 01-21-2012 07:33 PM
Need Help!- Sm1 well versed with mazatrol 640m or atleast ne mazatrol naren1608 Mazak, Mitsubishi, Mazatrol 0 03-22-2010 05:29 AM
Problem- Mazatrol T1 stevenchan Mazak, Mitsubishi, Mazatrol 1 07-09-2009 09:32 PM
does m-cam do mazatrol? underdog Mastercam 2 10-11-2005 09:30 PM
