Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-28-2010, 05:53 PM
Hastx is on a distinguished road
FJV-250 Splindle leaking oil!
Our shop just bought a used FJV-250 with 640M Fusion control, 12,000RPM spindle w/chiller. After I finished setting the machine up today I was running through a few tool changes and running the spindle at different RPM ranges, when I got up around 10,000 spindle oil started leaking from around the covers. I plan on taking the covers off in the morning and having a look. If anyone has any heads up on this for me that would be very helpful.
Old 05-29-2010, 09:11 AM
psychomill is on a distinguished road
What oil and what covers?
It's just a part..... cutter still goes round and round....
Old 05-29-2010, 12:42 PM
Headstock covers, spindle chiller oil!
Old 05-29-2010, 01:44 PM
I took headstock covers off today and the only thing I saw was there is a gap between upper part of spindle and lower bearings. Oil is feed in upper and lower parts. Air lines are feed in the gap a blow around the lower bearings. Looks like oil was building up in this gap and just slinging out when at high RPM. Dont know if its supposed to do that or not? I cleaned up all the excess oil and ran it again today for about 5-10 min and didnt see what i saw yesterday. Maybe something that just needs to be done as part of routine maintenance.
VF3 leaking oil out of bottom of spindle kbspeed Haas Mills 4 09-24-2009 05:10 PM
coolant tank lid leaking R.DesJardin Tormach PCNC 37 01-29-2009 08:18 AM
SL-10 leaking like an old dog? shawncnelson Haas Lathes 1 11-05-2008 02:42 PM
Newbie- Older Bridgeport splindle motor replace ddeaton Bridgeport and Hardinge Mills 10 03-12-2008 12:59 PM
Air/Hydraulic leaking problem?? bherr Bridgeport and Hardinge Mills 1 06-19-2007 10:50 PM
