Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-26-2010, 09:59 AM
IlikeJack is on a distinguished road
Cyber Tool Automation
Does anyone use Cyber Tool ID chips on their retension knobs? I use them but have some problems when reading the chip into the machine control. Any comments?
Old 05-27-2010, 10:42 AM
psychomill is on a distinguished road
Yep... use them....
What's the problem and what are you doing when you get the problems? (what are your motions)
It's just a part..... cutter still goes round and round....
Old 05-27-2010, 11:04 AM
After putting together a new tool and entering the data at the Mazak Control, I go to the tool magazine door and call the tool to the load position. When I press the ID button the message is 'TOOL IN MAGAZINE' and does not get registered. This does not happen to all the tools only certain ones. I know sometimes the operators pull the tools without pressing the OUT button. Could this be causing the problem? If so, how do I register the tool?
Old 05-27-2010, 11:11 PM
What machine is this? Are you running a chain or hive? ... and since you're entering the tool data at the control, I assume you don't have CTM software installed on a seperate computer?
If you're on Visual tool.... Yes. The memory still recalls the tool occupying the pocket. You should be able to verify that by looking in your Tool Layout page.
Old 05-28-2010, 07:25 AM
It's a HCN 6800 with a 160 tool chain. I do have a separate computer with the software but sometimes prefer to enter at the machine. If a tool is removed from the chain without pressing the OUT button will that pose a problem the next time the tool is placed back in the chain?
Old 05-28-2010, 09:03 AM
Yes because your CTM software on the PC is also tracking your tool chain. The proper thing to do is to use OUT when removing from the machine. Otherwise, the CTM software still thinks it is loaded in your machine which prevents your Tool Data from being uploaded... therefore you get a read alarm.
Make sure you properly pull the tool from the magazine every time. This moves the tool from the machine to "Unallocated" on your CTM software and continues to track it offline.
You can "back door" this if someone screws it up by using the Remove from Machine function (or something like that) on the CTM software (it's on the right half of the CTM display). Also make note though, if someone removes a tool like this but the tool still exists on the machine, you'll get an alarm at the machine for an unregistered tool.
Old 05-28-2010, 09:10 AM
Thank you, looks like a lot of operator training in my immediate future.
Need help with Hobart Cyber-TIG Jackal66 Welding, Brazing, Soldering, Sealing 10 06-29-2010 06:34 PM
Hobart cyber tig 300 weekendwelder Welding, Brazing, Soldering, Sealing 0 03-17-2009 09:20 PM
cyber-nc eman5oh General Electronics Discussion 0 09-27-2006 07:27 AM
cyber nc...HELP for newbie please!! banjopup Machine Problems, Solutions , Wireless DNC, serial port 0 07-23-2006 11:34 PM
Any info about cyber-nc? dmgdesigns DIY-CNC Router Table Machines 3 03-24-2004 09:17 PM
