Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-06-2010, 09:17 PM
fiat4726 is on a distinguished road
Setting a Tailstock on a Mazak T32
Can anyone tell me how to set the tool TPC on a Mazak T32 Machine? I have to use the tailstock. Someone has told me that the TPC numbers would be Z25.7 and X0. Is that true?
Old 05-06-2010, 10:06 PM
CNCRim's Avatar
Z25.7 X0? somthing tell me not right, how long is your part? Z25.7 will rapid toward spindle and X0 will toward center of the spindle.
Old 05-07-2010, 06:03 AM
jimiscnc is on a distinguished road
TPC and engaged tailstock
TPC in your case means "tool path control". (TPC can also mean "temporary parameter change")
The coordinate system in TPC matches the coordinate system of the unit it's applied to. So a BAR OUT unit using Z25.0 would be -25.0 in machine coordinates, as per the previous post. A minus Z in a Bar out unit would be to the right side of Part Program Zero, in other words.
So you have to program a "pass through" intermdiate point to go TO AND FROM turret index position (Parameter P17 for all except Matrix) to enter the mazatrol machining. A BAR OUT unit with rough and finish tools would require this to be done in TPC FOUR TIMES. rough approach, rough retract, finish approach, finish retract.
Plan B is to set P17 to 4, which sets the turret index position to a fixed point in machine coordinates as a departure from home/reference position. The magnitude of this departure is controlled by another set of parameters for each axis. The book says A5 parameter, (but this is off in Matrix parameter books.) The machine coordinates in Z should be set to get the turret face co-planar to the face of the shaft in the work area.
You can keep your global P17 for all normal stuff, and set P17 in the TPC to 4 for the times when a tailstock is engaged.
90% Jimmy, the Mazak internet fairy
How setting tools and setting offset John246 Sharp CNC 9 03-17-2010 09:31 PM
tailstock guydrisc Okuma 2 10-24-2009 02:13 PM
Help. Mazak Integrex. Setting tools on tool eye for sub spindle direction rdial22 Mazak, Mitsubishi, Mazatrol 2 03-25-2009 03:01 AM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 05:20 PM
