| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
My friend has a Yang Eagle 600 with a Meldas 50M he says that it does not have cutter comp. On the offset page he can enter a value but it will not comp it.It will just run the code as if there were no cutter comp. Can this be turned on somewhere else in the control? What good is a CNC with no cutter comp? Thanks john |
| Have him call Mitsubishi directly. They have a pretty good application guy over there. He can also talk with tech support for free about his problem. If he needs to clear the memory they should be able to walk him through it. Some times the memory becomes corrupt and needs to be cleared out but I would call them first and see what they say. Mitsubishi 847-478-2500 |
| It might also be worth looking at the manner in which he is calling it in gcode. Some controls have different rules about 'when and where' cutter comp is called, and what interposed commands can inadvertantly turn it off.
| Cutter Comp | Mooser | Tormach PCNC | 17 | 03-02-2012 07:37 AM |
| Cutter Comp | Farmers Machine | CamSoft Products | 6 | 11-18-2009 10:33 AM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 06:30 PM |
| Cutter Comp? | donl517 | Fadal | 5 | 07-03-2007 08:36 AM |
| Cutter Comp. | Big"E" | General Metalwork Discussion | 8 | 03-28-2007 11:05 AM |
