Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-05-2010, 08:49 AM
evrgrecnc is on a distinguished road
Mazak Vqc 20/40B error massage
Hello
error # 245 orient Malf 2. Description says: the orientation unit did not activate with in 10 seconds of being commanded (power supply interrupted)
error #251 spindle motor controller malf. An alarm signal was given by the spindle controller
How to remove or correct these error.
Machine have AC SPENDLE CONTROLLER MODEL FR-SX
Any help appreciated
Old 05-05-2010, 04:18 PM
Leelund is on a distinguished road
Power off at the main disconnect and wait 15 seconds. Turn power back on and see if alarms return. If not try spindle orient again. Maybe just a machine quirk.
Old 05-05-2010, 07:35 PM
thanks for reply, I already did couple time but nothing happened.
Old 05-06-2010, 04:18 AM
List what alarm number is on the controller. At this point, since the controller has been turned off/on, the original alarm on the spindle controller may have been reset. Anyway, power off the main and lock out. Inside the electrical box, take off the metal cover of the spindle controller. Swing open the hinge panel and inside you will find three little white fuses. Check them to make sure none are blown. They protect the controller power supply and heatsink cooling fans. Look for anything unusual, like something has melted or exploded. Also, there is a large 3 phase breaker on the input power side, make sure this has not tripped. Depending on what alarm or occurence you are having on power up will determine what to do next. Some of the guys here will get more in depth in rebuilding the controller and have such experience. We pull it and send it out if it's not something simple. Maybe some of the DIY guys can chime in.
Lee
Last edited by Leelund; 05-06-2010 at 04:19 AM. Reason: Fat fingering and spelling.
Old 05-06-2010, 10:35 PM
Thanks Lee
Alarm # LED 14 (AL2) red light.
Fault indicator says
1: N/A
2: EXCESSIVE SPEED ERROR
3: BLANK
4: N/A
5: N/A
6: EXTERNAL EMERGENCY
7: OVER SPEED
8: N/A
9: N/A
10: UNDER VOLTAGE
11: OVER VOLTAGE (CONVERTOR)
12: N/A
13: N/A
14: CPU FAULT-2
15: CPU FAULT-3
I checked fuses and they are OK. I checked 3phase breaker too and seem to me ok.
Thanks for help
Gideon
Old 05-07-2010, 03:57 AM
Found this attachment in my notes:
You will find Mitsubishi notes good at pointing you in the correct direction but usually you will have to embellish some from what they say to do.
File Type: pdf ALARM_FR-SE_OR_FR-SX_EXCESSIVE_SPEED_DES.pdf‎ (8.0 KB, 78 views)
Mazak QT-6T Program Error flomatic Mazak, Mitsubishi, Mazatrol 4 04-07-2010 11:10 AM
Problem- Display massage : BROKEN WIRE MajaF CNC Wire Foam Cutter Machines 2 01-12-2010 12:59 AM
Mazak M32-Parity H Error compuslave Mazak, Mitsubishi, Mazatrol 4 02-04-2009 03:25 PM
Laser Operator Massage ounsiam Laser Engraving & Cutting Machines 0 04-19-2007 11:05 AM
Mazak VTC20 error ZipSnipe Mazak, Mitsubishi, Mazatrol 1 09-22-2006 11:46 AM
