Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-30-2010, 11:59 AM
kwmkoester is on a distinguished road
Patrol Lights on Quick Turns
I need to install some Patrol Lights in a few QT's(varying vintages), does anyone know if a standard Mazak QT comes(in a standard configuration) with the ability to install them without adding anything but a wiring harness to the lights? If anyone can help I would appreciate it. If I do have to add relay logic what are the best signals to use? Thanks.
SL-10 lights-out running? shawncnelson Haas Lathes 15 04-20-2009 09:44 PM
4th axis turns to many turns cob Mastercam 6 02-16-2009 12:19 PM
Problem- TNC 145 cs Lights On mjp Bridgeport and Hardinge Mills 6 01-18-2009 08:25 PM
I'm done, but nothing turns pbarsalou DIY-CNC Router Table Machines 11 04-07-2007 11:15 PM
Running Lights out gizmo_454 Haas Mills 15 04-04-2007 05:32 PM
