Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-23-2010, 06:28 AM
careyp's Avatar
careyp is on a distinguished road
Mazatrol T1 problem
I recently had to repair an old slant turn 40 with a Mazatrol T1 controller. I foolishly disconnected the 3.6v battery pack and lost both the parameter data, which was smartly backed up on paper, and all the tool data and tool set data. I was able to input the parameters, but the tool data and tool set are still missing. Although the turret holds 15 tools, the tool data page shows tools 1 thur 8, then 21 thru 24, then 60 thru 63. The manual has a picture showing this same thing. The operator says it used to go 1 thru 24. My question is:
1) what is the actual procedure to input tool data? How do i measure tools and inserts.
2) Is there a way to create tool data numbers 9 thru 20?
3) What does the tool set do, and does its data come from the program or from manual input.
I have been out of the CNC game for a while. Any advice would be appreciated.
Old 04-23-2010, 05:03 PM
careyp's Avatar
Update: itturns out thet most slant turn 40s have only 8 tools on the outside ring (1-8) and 4 on the inside (21-24), so when I put in the parameters, it decided that it was an 8 tool machine. i discovered that the SQ parameter on the second parameter page controls the machine configuration with a 16 bit number. the 10 tool turret is bit 32. I tried various values of the different options and rebooted the controller, but so far no luck. I'm glad its friday and I don't have to see it again till monday.
Mazatrol T1 Problem, Can Anyone Help? mattme Mazak, Mitsubishi, Mazatrol 17 08-14-2010 10:21 AM
Problem- Mazatrol T32 -turning problem Bert10 Mazak, Mitsubishi, Mazatrol 2 09-20-2009 01:31 PM
Mazatrol M2 DNC connection problem, ISO programs ddanutz1 Mazak, Mitsubishi, Mazatrol 10 08-09-2008 05:38 AM
Mazatrol t1 qt10 cpu problem diz Mazak, Mitsubishi, Mazatrol 0 10-17-2007 07:29 AM
problem with programming mazatrol t1 diz Mazak, Mitsubishi, Mazatrol 2 04-04-2007 07:00 PM
