Results 1 to 4 of 4
Thread: Mazatrol Dual Turn Fusion 640T (Door lock question)
    May 2008
    I currently operate a Dual Turn Mazatrol fusion 640T at my workplace. I was wondering if anyone knows how to turn off the door lock? Also, is there an option to allow the chuck to run with the door open, or is that safety feature hard coded into the machine?
    Registered CNCRim's Avatar
    Feb 2006
    one simplest way is clip the switch on the door, then the machine will let you run with the door open.
    Nov 2010
    indonesia
    alarm 26. illegal parameter
    I have problem with machine MAZATROL FUSION 640T/MT/TE, Alarm illegal parameter, can you help with that
    thank's
    aaagt78
    Registered mantenim's Avatar
    Sep 2008
    Mexico
    Quote Originally Posted by Sammeh View Post
    remove the door key and place it into the door-lock.
    or
    in the diagnosis display, push (I/O write). write X7-1, and input.
  1. Need Help!- Fusion 640T SQT 200MSY Y-AXIS
    By Darchon in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-25-2009, 05:49 AM
  2. pc fusion 640t
    By strecha in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-08-2008, 11:00 AM
  3. FUSION 640T BIOS
    By APEXWARRI in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-22-2008, 12:21 PM
  4. SQT 250M / Fusion 640T Tail Body Question
    By stinkysump in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-22-2007, 10:25 PM
  5. PC Fusion 640T - fdd problem
    By nicolabucci in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-06-2006, 01:59 AM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
