Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-12-2010, 02:29 AM
sve0019 is on a distinguished road
Mazak Mazatrol M-2 Rapid
Hello CNC people.
On the mazatrol M-2 control It is 2 buttons for more feed and
less feed 0 to 200 percent.
To left off more feed button is a button looking like a rapid
movement (long wave with 2 arrows pointing down.)
Quest. Can somebody on the site tell function off that button?
Sve0019
Old 04-12-2010, 04:30 PM
gridley51 is on a distinguished road
The button is called "Rapid reduce"
According to the manual it`s a key to slow the feed speed from the reference speed.
A decelerating speed is to be set in the parameters.
Please don`t ask me what all that means.
Mark.
Old 04-22-2010, 11:53 PM
Mazaman is on a distinguished road
It cut's the rapid ''go" moves in 1/2 .
Old 04-25-2010, 06:33 PM
MAZAKMAN21 is on a distinguished road
are you talking about your spindle jog buttons? If your are when you go into manual mode if your spindle has two gears you need to pick one. After you select a gear you can press spindle start and you can jog the spindle rpm up and down.
Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english tuanpq Mazak, Mitsubishi, Mazatrol 21 01-21-2012 07:33 PM
Mazatrol T1 - Mazak valvulin Spanish CNCzone 0 10-31-2008 04:17 PM
Mazak, Mazatrol T1 valvulin Spanish CNCzone 1 10-10-2008 12:17 PM
mazak(mazatrol-m1) mohd khalid Mazak, Mitsubishi, Mazatrol 3 07-06-2006 10:47 AM
Mazak H15 with Mazatrol M2 Steve_rb Machine Problems, Solutions , Wireless DNC, serial port 1 03-19-2004 06:27 AM
