| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Dear All, My machine got problem again. Need experts help to solve this issue. When I press the softkey "PROGRAM", it cannot access in. came out a error (see pic). Can anyone advice on it? Tks ![]() ![]() |
| Go for the simple stuff first. There is a slim possibility this is a result of the ascii text trick when in program display. set up an ascii text printer on the windows side for a system printer. pick a paper size that's wider than height. file-print-print to file, and a few other settings will create a print file that's text so you can print out the mazak mazatrol program. on a piece of paper - for study or as a set up sheet or for what ever reason after doing this, you have to do it again with the CORRECT path to standard program storage. to not go back to the original setting, it saves the programs in a directory unfamiliar to mazatrol, and you can't edit your programs any longer. or something like that. good luck! jim |
| Hi, Un-installing the MainB s/w in the HDD does not affect the parameters. However you should be sure enough, the same version files exist in the \NCBackup folder. Otherwise you will have no setup files available, to install the Mazatrol (MainB) s/w. I feel it is safe if you prepare a spare clone HDD of the original, using norton ghost s/w & USB-IDE adaptor. Try whatever you want to, on this clone HDD. Even if you spoil the windows files, you have the original HDD to get back to the point where you started. Regards, Girish |
| Using GOTO in a mazak program | CAMCRASH | G-Code Programing | 8 | 03-16-2012 05:31 AM |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 08:19 PM |
| Mazak M32-Parity H Error | compuslave | Mazak, Mitsubishi, Mazatrol | 4 | 02-04-2009 03:25 PM |
| Mazak Program Restarting... | Bloodeye | Mazak, Mitsubishi, Mazatrol | 2 | 06-07-2008 07:28 AM |
| Mazak VTC20 error | ZipSnipe | Mazak, Mitsubishi, Mazatrol | 1 | 09-22-2006 11:46 AM |
