Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-06-2010, 12:41 PM
mookh1 is on a distinguished road
mitsubishi Freqrol-fr-sf spindle drive unit
Any ideas anyone.
machine cuts out on alarm23, spindle will not turn. put unit in open loop condition to test feedback, dont get alarm or cut out, just sits there with spindle not rotating. can anyone help? or point in right direction to find fault. Also does anyone know the correct mcode to activate/deactivate second spindle on a TX-8F control.
mookh1.
Old 04-06-2010, 01:05 PM
girishdk is on a distinguished road
Need Help! mitsubishi Freqrol-fr-sf spindle drive unit
Did you check the Power Cable continuity from Spindle Drive to Motor?
Is there any star-delta change over contactor between drive & motor power connection? If so, is any one of them on, when the spindle command is given?
Because there is not even slight rotation of spindle, the first suspect is this case is the power cable.
Regards,
Girish
Freqrol Spindle Drive is Dead mbpp Mazak, Mitsubishi, Mazatrol 5 01-25-2010 11:33 AM
Need Help!- Mitsubishi FREQROL problem eva_1686 Mazak, Mitsubishi, Mazatrol 12 12-21-2009 08:06 AM
Need Help!- Boxford TCL160 interface to Mitsubishi Freqrol drive and a few other questions M100 General CNC (Mill and Lathe) Control Software (NC) 0 07-23-2009 06:58 PM
Mitsubishi Servo Drive Unit kkulture8 Want To Buy...Need help! 4 02-16-2009 02:18 PM
Need Help!- MITSUBISHI SPINDLE DRIVE UNIT MDS-A-SPJ-75 chagin General Metalwork Discussion 0 08-09-2008 12:19 AM
