Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-05-2010, 01:17 PM
kendo is on a distinguished road
corner radius
this is a pocket unit on a vertical nexus mill with pc fusion 640M
the shape is a simple square,
using a 1/4" endmill, and all four corners set at zero chamfer/radius
the tool still arcs in the corner to make a 1/4" radius for some reason
Old 04-05-2010, 01:49 PM
CNCRim's Avatar
Check Tool Data page, suspect tool definition is wrong.
Old 04-05-2010, 02:06 PM
tool is defined as endmill
nominal: .25"
actual: .25"
plus, the X-Y size of the pocket comes out perfect
Corner Radius Tools? machred23 SolidCam 4 08-17-2009 11:09 PM
Looking for Woodruff Cutter with Corner Radius mgb1974 General Metalwork Discussion 0 09-18-2008 10:20 AM
? about ball-end, corner radius endmills dkaustin Tormach PCNC 3 08-29-2008 10:03 PM
Radius on the corner of square stock ErnieD General Metalwork Discussion 5 03-30-2008 09:35 PM
How to put a radius on the outside corner of a square? Xterrian G-Code Programing 4 10-13-2005 08:21 AM
