Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-26-2010, 09:33 AM
Bullet605 is on a distinguished road
Mazatrol M-32 I/O communication problems
I have a M-32 controller on a Mazak V-515 that I am unable to upload any program to, from a PC. I have looked through other similar post and tried the different suggestions without any luck. I have tried 3 different cables including the one that came with them machine and the other2 that I know work from different machines. This machine is new to me and I learning the M-32 controller so I don't know if it a procedure error, problem with the cable or myself... I would appreciate and help.
The machine had sat for a while and lost all the parameters which I had to reenter manually. Here is what I have the following parameters set to which I believe to have an effect on the I/O:
G19 2
G20 3
G22 0
G23 3
G24 1
G25 0
G26 0
G27 0
G28 0
G29 3
Old 04-17-2010, 12:05 AM
culminater is on a distinguished road
griffo bros
what software are you using
all mazak needs is a baud rate of 4800
i believe
Tags
m-32, m32, mazak, mazatrol, mitisubishi
Mazatrol T-Plus RS-232 communication kroner1 Mazak, Mitsubishi, Mazatrol 11 01-06-2012 09:05 AM
Mazatrol CAM-M2 communication cable Matei Mazak, Mitsubishi, Mazatrol 15 11-06-2008 02:20 PM
Mazatrol T1 communication parameters? sinjin341 Mazak, Mitsubishi, Mazatrol 3 07-22-2008 03:35 PM
Need Help!- Mazatrol CAM T4 communication serickson Mazak, Mitsubishi, Mazatrol 2 05-06-2008 07:06 AM
Communication Problems dillweed General CNC (Mill and Lathe) Control Software (NC) 1 10-18-2006 10:12 AM
