| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
mitsubishi meldas; if jogging machine using jog button or in handle mode for whatever reason and then running prog in auto or tape mode the control will lose itsprevious known position and it must then be homed again and reset this is very annoying and time consuming as sometimes it may take a number of times before it remembers where it is again. when you home the machine after power up even tho all xyz axis home lights come on it can also likely not know its position and the start up procedure must be repeated sometimes numerous times Note, the machine once set up having run a prog in the right place once is then 100% reliable and will not lose its position unless manually moved |
| MITSUBISHI 520 AMR | CHANDRU | Mazak, Mitsubishi, Mazatrol | 3 | 01-02-2010 09:31 AM |
| Need Help!- "Y minus" loses steps on accelleration | Mal Buckmaster | Machine Problems, Solutions , Wireless DNC, serial port | 3 | 06-08-2009 06:56 AM |
| Need Help!- BRIDGEPORT CNC SERIES II R2E4 loses program | beaver | Bridgeport and Hardinge Mills | 4 | 05-19-2009 08:22 PM |
| 0-MD Machine loses absolute coord with reset | ILCORKILL | Fanuc | 6 | 02-25-2009 11:41 AM |
| Mitsubishi M-H5B | tturnbull50 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 09-29-2008 01:09 PM |
