Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-01-2010, 06:06 PM
lx545 is on a distinguished road
640m g-code
I have a 640m fusion control on a 655/80n mill and Im trying to run a eia subprogram in a mazatrol program. I have the program correct accept it does not recognize the dia of the tool in mazatrol its working kind of like a line center if that helps. I set the f94 and two other parameters and tryed offsetting but Im not real familiar with what to do, and help? thanks
Old 03-02-2010, 01:05 AM
Mazachist is on a distinguished road
The machine is set up to use tool data for mazatrol programs and tool offsets for g code programs. You may need a G43 Hxx and G41 or G42 Dxx in your program. Restarting your machine after changing F94 bit 7 may be necessary.
YO
Old 03-02-2010, 08:21 AM
jimiscnc is on a distinguished road
Mazak gives EIA programmers a choice for TLC and CRC - do it standard G code way (aka "fanuc way") or do it the very elegant "Mazak way", as described below.
CRC:
CRC with D offset register: F92.7 = 1 (D word uses EIA offset registers)
CRC by "mazak way" F92.7=0 (uses Mazatrol TOOL DATA and offsets path by ACT-DIA)/2 in Mazatrol Tool Data. Still need G41/42 but D word not required
TLC:
TLC with G43 and H word: F93.3=0 (H word uses EIA offset registers)
TLC by "Mazak way"" F93.3=1 (tool length "goes with the tool" in and out of the spindle and stays in the coordinate system until tool change. Tool length value is in Tool Data page)
Note: RESET will wipe out EIA type using G43, RESET DOES NOT wipe out mazatrol way!
from notes. be forewarned; I did too much acid back in my hippy days!
-jim
PS - F94.7 is the switch for using H/D or not. I prefer Mazak way greatly, so I don't use F94 much.
Mazatrol 640M/ EIA program inkydo69 Mazak, Mitsubishi, Mazatrol 5 07-02-2009 05:00 PM
Need Help!- Mazatrol 640M hense Mazak, Mitsubishi, Mazatrol 2 02-11-2008 11:56 PM
E 650 W/640m Control RADMASTERD Mazak, Mitsubishi, Mazatrol 6 11-29-2007 03:13 PM
fusion 640m rs232 comm camcutter Mazak, Mitsubishi, Mazatrol 3 05-30-2007 11:23 AM
640m ethernet mshodges Mazak, Mitsubishi, Mazatrol 3 11-21-2006 02:07 PM
