Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-24-2010, 11:11 AM
jolulank is on a distinguished road
NO ACTION AFTER "TAPE I/O" MAZATROL T2
I am trying to send and receive programs to/from my Mazak QT10, it has a MAZATROL T2 control and I use Dan's PC-DNC software (licensed user).
I have succesfully sent and received CMT type programs and stored in my computer, BUT I have not been able to send/ receive EIA programs.
first question, Do I use the same CMT db25 connector or do I need to use the other one that is represented as a series of ones(serial I suppose). This other cable goes back to where the control is and hooks up directly into the FX107 board in the FX17 unit.
Second question, How can I get a response after pressing the TAPE I/O softkey? after "Program file", then "Data I/O", then "Tape I/O", then instead of getting "Load" I get nothing.
Thank you
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Need Help!- Mazatrol Fusion 640 M "Copying Y1 to Y2" Inzane8870 Mazak, Mitsubishi, Mazatrol 0 03-23-2009 09:37 AM
Need Help!- "Warco GH Univ" V "Chester Lux Mill" JQ_Quint Benchtop Machines 37 01-22-2009 10:59 AM
