Oh I know, I don't want to edit the ladder for parameter changing. I want print the ladder so I can study it at home. Please tell me how I load the data in the PLC IF page
In PLC IF page, you find at the bottom side as below
DEVICE DATA MODE
In device you need to enter your L or R bit number. Once you enter the details in Device and press input on keyboard, the particular L/R bit details will be displayed on screen.
To force/change the value of L/R bit, you have to enter the value in data and in mode you need to enter 2
For example if I need to change by L007F to 1, then
DEVICE DATA MODE
(L007F) ( 1) ( 2)
In screen, you will observe as below, if successfully changed
i have Mitsubishi meldas 64 controll on multispindle drilling machine,
because of dead battery , i lost its parameters which were not saved ,
can you provide me its parameters ,
thanks for your help,
I have a hartford machining center, whitch work with meldas magic64.
I need system floppys
Meldas magic64 nc system disk 1 and 2
Meldas magic utility disk 1 and 2
Meldas magic meldasmagic monitor disk 1
Meldas magic custom API library runtime disk 1 and 2
Meldas magic64 NC data 64m disk 1
Please help me
If u have these floppy's please send me a soft copy
