need help mazak alarm 31
Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: need help mazak alarm 31
    Sep 2007
    mexico
    Default need help mazak alarm 31
    Hi, i have a mazak m-plus cnc that bring the alarm "31 servo malfunction 1", in my manual only appears alarms from 200 and above, does anyone know the complete explanation of the alarm? From the number 1 in the alarm i would think it refers to x axis.
    All the axis controller goes to E7 (e-stop), but none of them shows any different alarm.
    Anyone?
    Mar 2005
    Silicon Valley, CA
    Check your drives and see which one is in alarm. With servo alarms, you have to power down to clear... you have tried that right? If it's still there, check the drives to see which one shows alarm and look up the alarm in the Mitsubishi book or call Mitsubishi... maybe a bad drive...
    It's just a part..... cutter still goes round and round....
    Jan 2008
    MDS Alarm S01 0031 6.98KB PDF
    Overspeed - The motor is operating at a speed faster than machine parameters allow.
    Regards,
    Chippy
    Sep 2007
    mexico
    When i turn the machine off and on again the alarms dissapers and the cnc works for 2-5 minutes and again i have the alarm. Sometimes the alarm appers when i turn the controller on, i doesnt even move.
    The drives only show F1 E7 ....F4 E7.....F3 E7.....and so, but none of them show any different alarm than E7, the alarm "31 servo malfunction 1" only appears at the operator panel, but no on the drives, thats what i dont undertand.
    Help anyone?
    Jan 2008
    What kind of machine do you have? What is the model?
    Regards,
    Chippy
    Sep 2007
    mexico
    The machine is a mazak vtc-20b with a mazatrol plus control
    Thanks in advance
  7. #7
    Jun 2008
    Default Alm 31
    Alarm 31 is a servo power off malfunction. Check the servo power supply for voltage into and out of.
    Lee
  8. #8
    Jan 2008
    Are you reading the alarm at the bottom of the operation pamel? If so, please go to the maintenace scren and give us any additional information regarding the alarm. Sometimes there are () from the right of the alarm with additional numbers.
    Regards,
    Chippy
  9. #9
    Jun 2015
    México
    Default Re: need help mazak alarm 31
    Quote Originally Posted by jaimeeduardo View Post
    Anyone?
    This
    is the answer
    Alarm No. 43 from the driver unit
    36) Alarm No. 43 Feedback error 2[Meaning] 1) A deviation occurred in the feedback amount from themotor end detector and machine end detector in the closed2) The serial pulse encoder is detected in the semi-closedloop.
    We had the same problem at Z axis we could fix it after we changed the encoder
    Best regards
    https://s3.amazonaws.com/Icarus/DOCU...anuals_538.pdf
  10. #10
    Jan 2008
    Quote Originally Posted by RASEC View Post
    This
    is the answer
    Best regards
    Go to the Maintenance screen and submit the whole alarm; typically there are a set of parenthesis with additional letters and number to the right of the 31 servo malfunction 1?
    Chippy
  11. #11
    Registered EliseoMonteverd's Avatar
    Dec 2007
    Uruguay
    Enviado desde mi GT-I9500 mediante Tapatalk
  12. #12
    Jun 2015
    México
    Hello Eliseo
    Could you share us this manual?
    My mazak
    it does not have manual with the alarms
    Best Regards
