Need help to program a milling process. Machine is a QT-200MS LATHE year 2010. the part is a bar of 1" diameter and 2" long. I need to program a milling line with a mill of 10 mm diameter using the C and X axes. The tool have a radial orientation. I would like to indicate the tool to go by the center of the line and in this way obtain a flat face with 10 mm width and 1,5 mm depth in the X direction. The C axis shall move from 0 degree to 60 degrees simultaneouly with the X axis moving In and Out. Can someone help with the program?.
In the old Mazatrol I have made this type of process before but in the new controller I have some inputs like "I" and "J" that I do not know the meaning.
