Hi Guys, Trying to get drip feeding to work, but I don't have anyone in the real world to ask, and basic instructions online are scarce, so I'd appreciate a hand! I've got upload/download to work, so I thought great, set the tape device to the same as the input/output device in the I/O parameter, go to tape mode, type program number, send from pc, press input, easy money. Not so. I've tried this, it just says 'not found', I've also tried dev(1) as well as dev(0). Could you tell me where I can find, or tell me, the basic instructions to get this to work, so I can work out if its a parameter setting or if I'm just doing it wrong. Many thanks!
Hi James, have you figure out how to drip feed? I am in the same exact situation as when you posted this. Like you stated there isn't much available info online and the original controller instructions don't say much on tape feeding let alone drip feeding. Thanks
