Generally the reason for the *** is wrong or missing parameters.
Did you put in the check sum digit for the OP parameters?
We have a Mazatrol T1 where after a changing the battery gives ***.** for both X and Z axis position.
We already put back all the parameters but still the position is not showing up.
Any idea what could be wrong here ?
Thanks for your input.
Marc
- Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
- How to change Tool change position(About MAZATROL T1 control)
- Position Page and Relative position
- Need Help!- Sm1 well versed with mazatrol 640m or atleast ne mazatrol
- Need Help!- How do i get the Fadal to show my zero position instead of its home position?
For example if the OP para is 01001100 it would be entered 010011003.
Case solved. We had to reenter every parameter, even the correct ones. Probably some corruption.
Thanks,
Marc
We still have a little issue in automatic mode.
In manual mode all goes fine, but lets say that in automatic we specify that the diameter must be 50, then it gives us a diameter of 50.225 and it also shows this on the screen, so in my humble opinion, there must be somewhere an offset defined by a parameter.
Someone has a list of the meaning of each parameter so we can verify this ?
Thanks,
Marc
Is it always out by 0.225 regardless of Dia?
I'll check with the operator tomorrow but i think it does.
Marc
Confirmed. The offset is always the same.
Marc
The looks most likely to be a parameter out.
I looked through them and couldn't really zero in on the one in question, maybe try a couple of small changes one at a time and see if any diff.
Some definitions attached.
Thanks Al.
I'll try.
Marc
Probably a stupid question but have you set your tool data correctly?
Regards Bob
We used the same parameters as before, when everything worked fine.
I must admit that some parameters were difficult to read (photos of the screen), so perhaps we made an error there.
Marc
Did you ever figure out why you were getting an offset? Same thing seems to be happening for us.
