Problem 410A M64 errors
Results 1 to 5 of 5
Thread: 410A M64 errors
    May 2013
    Default 410A M64 errors
    Mazak 410A mill
    Here is what I know please feel welcome to provide any input on how to proceed.
    • Worked 100% fine until today
    • Windows boots
    • Fails to load M64 (Fusion 640) on startup, produces m64groupA.exe, m64groupB.exe, and m64misc.exe errors.
    • HR113 board displays a 9 in the back
    • On the computer DC IN = Green, DC OUT = Green, PS EMG = OFF, BAT ALM = RED
    May 2013
    Default Re: 410A M64 errors
    I have now located the most recent backups, anyone have experience with this mainte.exe for reloading the sram? The manuals do not have anything that I have been able to
    Sep 2017
    Bahrain
    Hi bak3r11
    1) Please confirm the 7 segment status on drive unit.
    2) Since the BATALM LED is on (RED), you need to check the battery voltage. The voltage should be in between 3.2V to 3.6V,, else please get it changed.
    Please let me the know above two to guide further
    May 2013
    The 7 segment display reads 9. The battery is 1v. Already got a new one.
    Sep 2017
    Bahrain
    Quote Originally Posted by bak3r11 View Post
    Hi bak3r11, have you solved the issue?
    After replacing the battery, you will have to initialize the sram by keeping the rotary switch of motherboard. After that format the nc data by going to diagnosis data erase. One this is done you can load the backup through mainte.exe
410A M64 errors
410A M64 errors
