Need Help! MAZAK model VTC-20B does not start!!
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: MAZAK model VTC-20B does not start!!
    Oct 2017
    Chile
    Default MAZAK model VTC-20B does not start!!
    Good afternoon, I'd like some help and information.
    In the company we work with a machine MAZAK model VTC-20B with the Mazatrol M PLUS controller. What happens is that when you turn it on does not leave the screen with the Mazatrol logo (image 1 attached) and does nothing else. And at the bottom it shows an "INI motion" message.
    Nothing has been done to the machine, I would like to know if there is anything we can do.
    thank you very much
    Attached Thumbnails Attached Thumbnails MAZAK model VTC-20B does not start!!-img_20170928_113818-jpg
    Oct 2017
    Chile
    Default Re: MAZAK model VTC-20B does not start!!
    Hello, anyone who has information, even if they do not know the solution. Thanks.!!!
    Sep 2012
    Does it have a floppy drive? Is the disc in there? If not could be worth a try. With my T32 it works that way. Don't know anything about the M Plus
    Regards Bob
    Sep 2017
    Bahrain
    Hi hdealrosa
    Please share the LED status on QX084(or QX086), QX141(or QX141-1), QX522 for diagnosing the issue. These cards are mounted on the M PLUS NC unit
    Regards
    Navin
    Oct 2017
    Chile
    Hi sudsy, it does not have a floppy disk drive. Thanks for answering.
    Hi
    navinbhas, I will see the state of the led and tell you.
    Thanks a lot.
    Oct 2017
    Chile
    Navin, hello.
    Here is the information you requested.
    Regards.
    Attached Thumbnails Attached Thumbnails MAZAK model VTC-20B does not start!!-1-jpg   MAZAK model VTC-20B does not start!!-2-jpg   MAZAK model VTC-20B does not start!!-3-jpg   MAZAK model VTC-20B does not start!!-4-jpg
    MAZAK model VTC-20B does not start!!-5-jpg
  7. #7
    Sep 2017
    Bahrain
    Sry Delarosa, its not cleart which all card LEDs you have shared. Can you please update in below
    QX084, LED 1 = On/Off (Red/Green)
    LED 2 = On/Off (Red/Green)
    LED 3 = On/Off (Red/Green)
    QX141, LED 1 = On/Off (Red/Green)
    QX721, LED 1 = On/Off (Red/Green)
  8. #8
    Oct 2017
    Chile
    Good morning.
    The status of the LEDs are:
    QX084,
    LED 1 = ON - GREEN
    LED 2 = OFF
    LED 3 = OFF
    QX141,
    LED 1 = ON - flicker GREEN
    LED 2 = ON - flicker GREEN
    QX722,
    LED 1 = ON - RED
    LED 2 = ON - GREEN
    Thanks for your help
  9. #9
    Sep 2017
    Bahrain
    HI Delarosa..
    Thank you for sharing the data..
    QX722, LED 1 = on (RED) : Watchdog error LED is on.
    Could you please confirm the LED status on all drive units ?
    If the drive 7 segment displays are showing Ab, then check below points,
    1) Try removing the connections on QX722 card (if any). After removing, please power on and check if the LED remains on or off.
    2) Try removing the QX524/QX521 PCB from the slot and then check the LED status on QX722. IF QX524/QX521 has add-on memory card, please do not keep the card outside for more than 5 minutes.
    3) Try removing all the IO cards outside and check LED status on QX722
    In all these conditions if the status of QX722 is same, then the card needs to be checked.
  10. #10
    Oct 2017
    Chile
    hello navi, we made the indicated and now it is in the following way:
    QX084,
    LED 1 = ON - GREEN
    LED 2 = OFF
    LED 3 = OFF
    QX141,
    LED 1 = ON - GREEN
    LED 2 = ON - RED
    QX722,
    LED 1 = ON - RED
    LED 2 = ON - GREEN
    We reviewed the card and a simple view there is nothing irregular. We will see the option to change the QX722.Any recommendation with the change of LED, or the purchase?
    You have helped me alot, thank you.
    Attached Thumbnails Attached Thumbnails MAZAK model VTC-20B does not start!!-img_20171026_163127-jpg   MAZAK model VTC-20B does not start!!-img_20171026_163115-jpg   MAZAK model VTC-20B does not start!!-img_20171026_163144-jpg   MAZAK model VTC-20B does not start!!-img_20171026_163151-jpg
  11. #11
    Sep 2017
    Bahrain
    QX141 LED 2 = red is parity error, which occurs when there is data/memory corruption.
    As requested previously, could you please confirm the drive 7 segment status
  12. #12
    Oct 2017
    Chile
    The 7 segments are showing "Ab" and we got the following error on the NC Screen.
    Attached Thumbnails Attached Thumbnails MAZAK model VTC-20B does not start!!-whatsapp-image-2017-10-31-10-45-a   MAZAK model VTC-20B does not start!!-whatsapp-image-2017-10-31-10-46-a
  13. #13
    Sep 2017
    Bahrain
    Hi Delarose,
    Do you have the backup for this machine. If yes, then please initialize and load the data manually or via RS232.
  14. #14
    Oct 2017
    Chile
    Hi navinbhas, unfortunately I do not have the backups.
    There is some way to obtain them, they must be bought or I can get them with someone, do you know something about that?
    Thanks.
  15. #15
    Sep 2017
    Bahrain
    Quote Originally Posted by hdelarosa View Post
    Thanks.
    There should be a booklet with all the parameters written. If so you can manually type in. Sorry I wont be able to help source the backup from somewhr else
  16. #16
    Oct 2017
    Chile
    Hello, good morning, thank you very much for all the information you gave me, but in the end we contacted a technician who knows these machines and we request service for not having any backup of these.
    thanks very much.
  17. #17
    Jan 2013
    Iran
    Please let me know Z Axis Motor info for MAZAK VTC020C.
    I miss this motor!
    Thanks/
  18. #18
    Oct 2017
    Chile
    Quote Originally Posted by Alicnc View Post
    I miss this motor!
    Thanks/
    Hi Alicnc, sorry for the delay but I don't have information for this machine. We lost manuals, and backups.
    In the end we had to contact a technician who reviewed the faults and sold us the damaged cards.
  19. #19
    Member confyone's Avatar
    Aug 2017
    Mexico
    hi, i have the same problem all the only led in red is the led1 OF THE QX722 which indicates watchdog error. but I have no video signal, only the screen is orange without any sign of life.
    Do you remember which card you changed, can you share the status of the LEDs when the equipment works?
    Attached Thumbnails Attached Thumbnails MAZAK model VTC-20B does not start!!-20200826_193645-jpg
  20. #20
    Aug 2015
    Hey Confyone! Did you get it fixed?
    I have similar problem.
