Reviving a Mazak QSH-10 4axis with T-4
Results 1 to 2 of 2
Thread: Reviving a Mazak QSH-10 4axis with T-4
    Oct 2010
    Default Reviving a Mazak QSH-10 4axis with T-4
    I may need some extra help to revive a QSH-10 Mazak lathe with a T-4 controller. The lathe was purchased at a auction then disassembled to repair the ball screw support bearing but was not reassembled or test for a few years. So far I have found the electrical and mechanical manuals but could use the operational manuals.
    Anyone have the T-4 operating manual and programming manual?
    Attached Thumbnails Attached Thumbnails Reviving a Mazak QSH-10 4axis with T-4-20170623_165257-jpg
    Oct 2010
    Default Re: Reviving a Mazak QSH-10 4axis with T-4
    What mounts to the area the red arrow is point to? When air is hooked up to the machine, there is air rushing out of this area. Not sure if a pressure gage mounts here or a sensor?
    Attached Thumbnails Attached Thumbnails Reviving a Mazak QSH-10 4axis with T-4-20170624_091856-jpg
