I/O trouble with Mazak QT10 - Mazatrol T-Plus
Results 1 to 3 of 3
Thread: I/O trouble with Mazak QT10 - Mazatrol T-Plus
    Apr 2017
    Default I/O trouble with Mazak QT10 - Mazatrol T-Plus
    Hey Guys.
    I recently started in this company. We have a 1996 Mazak QT10 with Mazatrol T-Plus control.
    Before I started the machine was moved and some smart guy decided to cut off the RS232 cable.
    I had no information or knowledge how to do it but I have set it as my personal goal to make it work again.
    Here is what i have:
    -Win xp desktop with a db9 serial socket
    -DNC cable from a CNC-Shop (Pinout should be right since it was listed for this control and the seller confirmed it)
    -Ncnet lite software from cadem
    I have found several sources of parameters to try from.
    My current user parameters are as following
    Baud 4800
    2 Stop bits
    No parity
    8 data bits
    XON/XOFF handshaking
    No DC CODE parity
    IO wait time 5
    The Machine gives me 5 options for data transmission:
    CMT I/O
    TAPE I/O
    DNC I/O
    PRINT OUT
    COMPUTER I/O
    With CMT i get 551 CMT MIS-CONNECTED error
    With Tape i get NO TAPE READER PUNCHER OPTION
    With DNC i get NO DNC OPTION
    I havent tried Print out since i assume its for a physical copy of the program
    The only partial success i had is downloading a program via COMPUTER I/O but the programm looks like a complete mess.
    Here is an actual sample i managed to get out of the machine:
    00(MG3-
    G0Z.9
    G
    GA0B00D000
    G3H60.5K0.M.NP
    GH00.K0.M0.N0P00
    G5
    G6
    G
    G
    G9
    G0
    G300P0(5353000.50.Z.S000U.005.0030.0
    G30PMA
    G36PA5S300S3500.00U0.06..
    G0
    N.5Z0.0.0Z0.
    G
    G30P3AB0.5Z0.S300S3500.00U0.06..
    G0
    NA0.030.995Z0.55
    NA0.0.Z0.50.9996Z.55
    N3A0.0.5Z.955
    G
    G30PD0
    G5P3M0A0B00K0S00.
    G5P9M0A0B00K5S06.
    G5P9M0AB00K5S0.
    G5P36M0A0B00KS06.
    G5P36M0AB00KS0.
    M30
    Obviously when i try to re-upload it to the machine i get an error but i haven't really tapped into that since i would like to get a real program out of the machine as a start.
    I tried playing around with the Software parameters on the computer, the COM port via the device manager on windows and the parameters on the machine.
    Sometimes i managed to get a complete different kind of mess.
    Problem is i can't find any information on the internet on COMPUTER I/O. Everybody seems to use CMT or TAPE for mazatrol and EIA programs.
    I don't even know which parameter section actually affects the COMPUTER I/O (I have DV1 - DV8 in my user parameters and i know that DV1 is for CMT and DV2 is for Tape)
    When i select COMPUTER I/O i have the following options:
    LOAD TAPE -> NC
    PUNCH NC -> TAPE
    COMPARE NC= TAPE
    Since it says TAPE i suspect DV2 will affect this but I am not sure.
    Again i worked out all this information in the last couple of weeks and that is really all my expirience with I/O.
    I would greatly appreciate if anyone had an idea what else i could try. I already spent way too much time and nerves on weekends for this
    Mar 2017
    India
    Default Re: I/O trouble with Mazak QT10 - Mazatrol T-Plus
    Hi Curty
    I work as freelancer for Mitsubishi Cnc controls in india . I can solve your problem.
    Please mail me machine details,and data ,
    Why do u want to use Serial data transfer??
    Mail : hemanth@sjautomations.com
    Apr 2017
    Quote Originally Posted by hemanth007 View Post
    Hi Curty
    Hey Hemanth!
    Thank you for your offer! I'm not sure what more information about the machine you need? I tried to describe it as good as i can. If you have specific information you need, i'm sure i can get them.
    Do i have another possibility than serial communication? I only have a db25 serial socket at the machine.
    Sent from my HTC One_M8 using Tapatalk
