I have just purchased this machine, I was told that the battery was dead and replaced and parameters reloaded. I think the got some wrong. The tool data page lists tool numbers 11 thru 14 then 21 and up. I have a 8 position turret. I have read posts with this problem but the seem to end before the right parameter or the fix is listed. Also I am unclear with parameters SQ and TCH. Any help would be helpful.
Thank you to Mazak user for his help. I have the parameters loaded and so far the machine is doing what it is supposed to. I am wondering what made you think that it was a T2 control? Either way I'm trying to figure out the chuck and tail stock barriers and setting tools. I have run Haas and Fanuc lathes but this is my first Mazak so there is a bit of a learning curve. Thanks again for the help.
