Hi dear
Your might not have entered the option data . In M64 option data is lost when formatted. thats why you are getting e06 no spec alarm.
Regards
Hemanth.p
+91 9962328434
Hi Gents
I have cnc milling with meldas 64m control,with out APC coder, last week i was working on battery replacement and parameter back up (it was long sad story)
i didit manually, any way finally i could bring the machine back to life every thing is working fine except when i want to set G54 ordinates when i press soft key (work) I see G54 and the rest of the group the problem starts when i want to input in brackets once i press number five i get immediately an alarm (E 06 NO SPEC) and i couldnt set any value
so please if any one know's how to sort this problem out it will be really appreciated
thnx in advance for any help
rgs
- Need Help!- cnc moving in negative cordinates
- Problem- change Fanuc 0-M display cordinates
- Need Help!- No dots in cordinates
- Need Help!- Create pdf from bcc V23
- Create Arc
Hi dear
Regards
Hemanth.p
+91 9962328434
dear sir
thank you very much for your reply
please advice for how to get these missing option data, if you have at least similar machine , i contacted the machine builder in Taiwan they reply me with back up parameter but it was for different machine
that was even with different motor drive so it was useless , i called them again they said that the company was emerged to another bigger company ,
so if you have any back up parameter please send me ,
i have attached photo for the machine
thank you again for your help
Hello my friend.
I have the exact same problem. Were you able to find the solution? Can you help me out?
Please explain the problem
Please send me the details to my phone
My number +91 9962328434
I use whatsapp, FACEBOOK MESSENGER,Skype.
This is the image I get at the setup registry when I try to insert any data. E06 NO SPEC. All the rest of the machine is working properly. I contacted the machine's manufacturer and they instructed me to use parameter 1060 to format the parameters and re-enter them. I did as they advised but the result is the same.
Option data is specific from machine to machine also it changes from Controller to controller.please mail me the machine details and pictures so i can guide you
My Mail : hemanth@sjautomations.com
Hello, did anyone resolve this problem? I have the same issue. When I restore from the ALL1 backup I can access the G54 coordinates, if I turn off power and re start then I get the same E06 error.
Hello everybody,
I have the same problem. I get the error 'e06 no spec' when I want to enter the coordinates in G54, does anyone have a solution?
