I have a Mazak ST35-ATC MC with live tooling. I had a problem with my CA card on my spindle drive. I sent it to Mitsubishi which they repaired it. When I got it back it had no parameters in it. I had a copy of the original parameters and entered them. Everything works but my programmed RPM/SFM is about 30% higher than it should be. The mill motor only runs very slow and makes a squealing noise. Mitsubishi sent me the parameters that should be in it but when I put them in it it gives me a parameter error. I can use it like it is but I would like to get the milling motor working right again. Not sure what to do form here. Any help would be greatly appreciated.
