Hello Butechi.
You can see the activity of SBK and Feed Hold button by selecting the SYSTEM -> PMC-> PMCDGN-> STATUS to find down their address, then use it's address to find in the ladder.
Hello guys, i need to find parameters for SBK and FEED HOLD buttons and i don't find anywhere about them. I search in parameters manual but nothing.
Please help me.
- Need Help!- Fanuc series 18 i-M, Daewoo diamond series DMV-500s start up error
- Need Help!- Fanuc Robocut Alpha 0B with Fanuc Series 16-W control 910 SRAM Parity System Error
- Need Help!- GE FANUC α Series Control Motor Servo amplifier unit and Series 16-MB
- Need Help!- Fanuc series 21i-mb
- Newbie- Fanuc O-T Series B
Hello Butechi.
Thanks for reply.
Can the button FEED HOLD be activeted from parameters or i need to make modification in ladder?
Dear Buterchi.
Usualy the FEED HOLD button activated in ladder and named as *SP( G008.5), the LED is *SPL(F000.4). You can see the status of these signal by selecting PMC-> PMCDNG-> STATUS-> key in G08-> Enter and see on sreen( remember that Fanuc named the address as 7-6-5-4-3-2-1-0, that's mean the righ most work is .0), or you can tracking it by entered it's address in ladder monitor( usualy it's allways used OC contact, what's that meaning of * signal).
Hello guys, I solved the problem with FEED HOLD, so when i press it the spindle stops from rotation.The solution was a internal relay that needed to be activated.
